Sweat it out in style with Nike Outfits by joeyjstepp
[Yesterday at 01:28:35 PM]
Begin every match or workout in comfort and style by joeyjstepp
[Yesterday at 01:27:40 PM]
Find all our current markdown styles in one place by joeyjstepp
[Yesterday at 01:26:05 PM]
Ibat-ibang kababaihan... by rarevision
[August 20, 2019, 05:42:45 PM]
Landscapes & Seascapes For All by mcCoy!
[August 07, 2019, 11:15:58 AM]
Churches, Mosques, Synagogues etc - Places of Worship by rarevision
[August 07, 2019, 12:27:57 AM]
Mga Sikat... celebrity photos by rarevision
[August 07, 2019, 12:20:18 AM]
D7K+ Shoot - January 2013 by Miguelina
[August 02, 2019, 03:11:46 PM]
NEWBIE Seeking Advice: Pricing your image for a textbook? by Red_Jade
[July 23, 2019, 06:33:29 PM]
My Food Photography Shots by mcCoy!
[July 18, 2019, 10:18:02 PM]
Author Topic: Reverse Lens Adapter for Extreme Macro Photography  (Read 43397 times)
Offline Maclover
  • Trade Count: (268)
  • Liked: 28
  • EchoPhoto PH
    • EchoPhoto
« on: October 26, 2007, 03:31:36 PM »
Normal prime lenses can take sharper close-up photos when they are turned around backwards. A Reverse Lens Adapter lets you do this.
What does the Reverse Lens Adapter do?
One side of the Reverse Lens Adapter is threaded to fit the filter rim of your lens. The other side of the adapter has a lens mount like the one your camera lens has. Screw the adapter onto your lens' filter rim, turn the lens around and bayonet mount it into your camera. That's it. You can now shoot extreme macro photography.
Once attached, you will have to set aperture manually (your lens should have aperture ring). As to focusing, it is done by moving your distance from the subject. Moving the focusing ring usually has very little effect,
SPECIFICATIONS AND AVAILABILITY:
  • Construction: High quality black Annodized Aluminum
  • Feature: Camera mounting mark
  • Availability -
           - 52mm for Nikon F mount
           - 52mm for Canon EOS mount
           - 58mm for Canon EOS mount
Price: P 400 (for 52mm size), P 420 (for 58mm size) (free delivery via Air21 for Metro Manila orders)
Ordering is Easy
1. Email us your order with subject line: Pipho order. Please indicate the following in the email:
  • Kindly enumerate your order (Quantity and Product)
  • Kindly indicate your full name, email and contact nos.
  • Advise if you want to pick-up* your order or have it delivered** via Air21 courier
*   For Pick-up: Our office is located near Buendia-Taft area, Pasay City
**  For Air21 delivery: Prior payment via bank deposit (Banco de Oro) is required
2. Upon receipt of your email order, we will either process your order or get in touch with you for further clarifications
For clarifications on our product, please visit our website or email us. You can also send us SMS 0917-8254838 or 0922-8254838
« Last Edit: October 06, 2010, 04:24:42 PM by Maclover »
Opens:Mon~Fri(10am-6pm),Sat(by appointment)[/b]
Tel: 5517394, 2150793
Offline din
  • masarap ang Rodic's
  • Trade Count: (37)
    • Flickr Gallery
Re: Reverse Lens Adapter for Extreme Macro Photography
« Reply #1 on: October 26, 2007, 09:28:10 PM »
Many thanks Brian. I just got this and it is well made and sturdy. Perfect for the job.
For Canon users, you can also use your EF lenses. Listed below are the steps.
1. Mount your lens normally.
2. Set your desired aperture value.
3. Press and HOLD the depth of field preview button.
4. While holding the DOF button, unmount your lens.
5. Release the DOF button after unmounting the lens. Check the lens and you will see that its aperture is closed down based on the value you set in your camera.
6. You can now mount the adapter and the reversed lens.
Hope these helps.
do... or do not. there is no try.
___________________
| flickr | bedraggled mind |
Offline Maclover
  • Liked: 28
  • EchoPhoto PH
    • EchoPhoto
« Reply #2 on: October 27, 2007, 08:58:31 AM »
Hi Zando, nice of you to ask.
You can check the flicker site of the previous poster, Din Cordero, and see the nice macro photographs he has created. =)
Offline din
  • Trade Count: (37)
    • Flickr Gallery
« Reply #3 on: October 27, 2007, 05:41:36 PM »
many thanks Brian.
zando, in the first page of my flickr site, you will find images with the tag reversed lens. before, i used a duct tape to connect my reversed lens to my kenko tubes in order to achieve high magnifications. now, it is made simple by the reverse lens adapter.
you can also check out the thread started by edsel regarding reversed lens: http://www.pinoyphotography.org/forum/index.php?topic=17651.0 and his article as well on reversed lens: http://www.naturephotosociety.org.sg/ASP/Article.asp?DBAPublishDate=1/10/2005
hope these helps.
___________________
Offline zando
  • Liked: 8
  • Camera: Canon
  • Model: 5D Mark II
  • Nickname: Zando
« Reply #4 on: October 28, 2007, 02:05:43 AM »
Awesome macro photos!!!
Thank guys! How do you protect the reverse side of the lens when reverse mounted?
I like my coffee black as the devil, hot as hell, pure as an angel, sweet as love.
Offline KNJO
  • The Evil K
  • Ex - Org Officio
  • Trade Count: (150)
  • Liked: 165
  • If first you don't succeed, try photoshop.
    • www.karlorteza.com
« Reply #5 on: November 02, 2007, 11:18:22 AM »
place a tape on the exposed connectors. that does the trick. or if you have a clear plastic you can place it on the lens, however it may cause distortions...
Offline Maclover
  • Liked: 28
  • EchoPhoto PH
    • EchoPhoto
« Reply #6 on: November 02, 2007, 11:23:51 AM »
@KNJO, thanks for the tip. Appreciate it.
The easiest way of protecting the contacts would be to use 3M magic tape - that way, you don't worry about leaving any adhesive residue on the contacts. Hope this helps.
Offline lancas
  • Trade Count: (7)
« Reply #7 on: November 08, 2007, 09:52:39 AM »
can this be used with 50mm 1.8 prime lens?
capturing images with pride elegance and simplicity...
Offline Maclover
  • Liked: 28
  • EchoPhoto PH
    • EchoPhoto
« Reply #8 on: November 12, 2007, 05:06:20 PM »
Alan, thanks for the order. Yes, it can be used with 50mm lens
Offline zenglebron
  • Gender: Female
    • Over the Cuckoo's Nest
« Reply #9 on: November 13, 2007, 09:56:10 PM »
Can this be used with the nikon d40 kit lens?
Offline KNJO
  • The Evil K
  • Ex - Org Officio
  • Liked: 165
« Reply #10 on: November 13, 2007, 10:05:15 PM »
you can use this rings with any lens as long it has the same filter/thread size...
i purchased one from Maclover too, a 58mm, and i just found out that i can fit my 52mm thread, i just put tape it on the side. 2 for the price of 1, hehehe...  ;D
Offline zenglebron
  • Gender: Female
« Reply #11 on: November 13, 2007, 10:14:02 PM »
Thanks KNJO for the reply. Might get one for the kit lens
Offline KNJO
  • The Evil K
  • Ex - Org Officio
  • Liked: 165
« Reply #12 on: November 13, 2007, 10:25:24 PM »
no problem zeng, check this link and see how i compared the shots using a kit lens and on reversed ring adapter.
http://www.pinoyphotography.org/forum/index.php?topic=19835.15
Offline mika888
  • The One
  • Trade Count: (12)
  • Liked: 1
  • Your eye is the key.
« Reply #13 on: November 20, 2007, 04:03:28 PM »
Sir,
Ask ko lang if this will work with the Nikon D40x kit lens.  If pick up ko ito, pwede bang i demo on how to use it with the nikon d40x?  The location is near ECG mall or the Jam bus station right? Thanks
It's not just a camera, its a Nikon.
Offline allanandr3w
« Reply #14 on: January 12, 2008, 08:47:17 AM »
my share with reverse mode technique using two lenses, 18-55mm and 50mm rev. crop the photos due to lens vignette...
Offline BigDaddy
  • life is a journey....make every second count
  • Trade Count: (14)
  • Liked: 1
  • There is no rest for the weary....
    • http://www.rafiuy.multiply.com/
« Reply #15 on: January 13, 2008, 08:36:02 PM »
Also got this item from Brian a month or so ago.  I'll post a couple of macro shots for reference by other prospective buyers  ;D ;D ;D
...how far can you run into a forest?
...200 feet...500 feet...doesn't matter....you can only run halfway in, the rest of the time is spent running out
D300 | 18-200mm VR
Multiply: rafiuy.multiply.com/
Offline JBi
  • Trade Count: (8)
  • Liked: 1
  • Sharpening my Third Eye!
    • Jeruel Ibañez Photography
« Reply #16 on: January 13, 2008, 09:58:01 PM »
I want to have one, too!
Offline jasperjugan
  • Nido Kid
  • Feel the LOVE Generation!
    • jasper jugan - me, myself and i
« Reply #17 on: February 01, 2008, 11:21:32 PM »
nice product
Offline vulaq
  • Insomiac
  • Nido Kid
  • Joseph Nicéphore Niépce
« Reply #18 on: February 10, 2008, 12:11:34 AM »
Got my Reverse lens adapter last month, i never enjoyed macro photography until i had this device, thank's to Brian, he's one of the niciest person i know who is so humble but very well verse in photography, thanks Brian for all the help!!  ;)
Where you can find pipol who can fly...at night... CAPIZ joke joke...
Canon EOS 5D MARK II ; Canon 24-70mm L f/2.8 ; Canon 70-200mm L f/2.8 IS USM; ; Canon 50mm f/1.8 II ; Canon 28-135mm f/3.5-5.6 IS USM
Sigma 15mm f/2.8 Fisheye; Sigma 18-200mm f/3.5-6.3 OS; Canon 18-55mm kit lens
Canon Speedlite 580EX II with Demb Diffuser
Offline prespirit26
  • Camera: Nikon
  • Model: D80, D40x
« Reply #19 on: February 26, 2008, 10:29:07 PM »
So which is much better a reverse lens adapter or the Extension tube lens??
Last post March 05, 2008, 06:43:16 PM
by paparazc
Reverse Lens Macro Shots
Started by cthep2 « 1 2 ... 111 112 » Macro
Last post October 01, 2018, 01:28:18 PM
by Rundstedt
Last post February 16, 2009, 09:18:49 PM
by davidblaster
Last post August 06, 2011, 11:21:04 PM
by micoraven
Last post May 03, 2011, 12:26:33 PM
by glennalday
