Author Topic: Fujifilm X-T2 Announcement on July 2, Full Specs Leaked!  (Read 11115 times)
Offline gravija_flare
  • Liked: 12
  • Nickname: vt
« on: July 02, 2016, 12:59:03 AM »
with just a few days before the announcement, the full specs are now leaked:
– 24.3MP CMOS sensor
– Image processing engine X Processor Pro
– Video 4K30fps. Full HD60fps
– Video of the bit rate is 100Mbps
– The maximum speed of the shutter is 1/8000 seconds. 1/32000 sec electronic shutter
– Synchro speed of the flash is 1/250 seconds
– AF 325 points can be selected intelligent hybrid phase difference AF
– The body is in a magnesium alloy, improve the durability of the dial. Dust and water specification
– EVF is 2.36 million dots. Refresh rate 100fps
– 3-way tilting 3 inches 1.62 million dot LCD monitor
– Dual SD card slot. UHS-II support
– AF-C custom settings
– ISO range is ISO200-12800 (RAW)
– Wi-Fi built-in. Remote shooting correspondence. Instax Share printer support
– 16 kinds of film simulation modes, including the ACROS
– That can customize the settings screen “My Menu”
– Normal / boost mode switching
– 14bit RAW lossless compression. Camera RAW development
– Exposure compensation +/- 5EV
– 256-segment metering (multi-spot average, spot, center-weighted)
– Interval Shooting
– 13 kinds of creative filter
– The battery is NP-W126S. The number of possible shots 350 sheets
– 3.5mm microphone jack. 2.5mm remote terminal. USB3.0 terminal. Micro HDMI terminal
– You can use all of Fujinon X mount lens group
  • When the vertical position power booster grip use of the option, can use a plurality of battery at the same time, continuous shooting is speeding up, the shooting interval, shutter time lag, the image disappearance time is shortened. In addition, 4K of recording time is extended up to 30 minutes.
http://www.fujirumors.com/fujifilm-x-t2-full-specs-images-leaked/
« Last Edit: July 02, 2016, 01:03:55 AM by gravija_flare »
Offline retina
  • Global Moderator
  • Liked: 1046
  • Camera: Fujifilm
  • Model: Nikon D750
  • Nickname: Doc A
Re: Fujifilm X-T2 Announcement on July 2, Full Specs Leaked!
« Reply #1 on: July 02, 2016, 01:09:42 AM »
 Let the hype begins...sana magmura na ang xt1.
Offline romzL
  • Insect chaser :D
  • Trade Count: (12)
  • Liked: 305
  • Camera: OMG
  • Nickname: romz
« Reply #2 on: July 02, 2016, 03:33:48 AM »
oo nga Doc. Mas excited ako sa pagbaba ng price ng XT1. 2nd hand goes for as low as 35k so imagine once lumabas to. nasa 30k ish na lang ang XT1 or less hehe
<< Insert wise quote here >>
Offline retina
  • Global Moderator
  • Liked: 1046
  • Camera: Fujifilm
  • Model: Nikon D750
  • Nickname: Doc A
« Reply #3 on: July 02, 2016, 09:49:47 AM »
It has no touch screen. Needs a grip to take advantage of 30 minute 4k video. It has a joystick though which i think very nice to use like in the xpro2 and d500. That 4k seems to suck a lot of juice from your battery. I hope there will be no heat issue . This cam i think remains to be a photo still shot centric one. i wont get excited with the 4k feature. The reduced price of xt1 is more exciting . If it wont happen the would be gassers will part with their xt1 at lowballed prices. Remember  if you are into 4k video you should add up the price of computer upgrade .The foremost is the GPU that cost around 18-20k.The af must be very good and formidable for me to pick this up over the xt1..my 2 cents opinion of unrelease product. That could change though..who knows?
  • Liked: 12
  • Nickname: vt
« Reply #4 on: July 02, 2016, 11:46:36 AM »
well it seems the add-on grip also has the af select stick.
http://www.fujirumors.com/leaked-see-real-life-fujifilm-x-t2-vertical-grip-attached/
« Last Edit: July 02, 2016, 11:48:32 AM by gravija_flare »
Offline retina
  • Global Moderator
  • Liked: 1046
  • Camera: Fujifilm
  • Model: Nikon D750
  • Nickname: Doc A
« Reply #5 on: July 02, 2016, 05:38:00 PM »
The grip will add more battery power and you can shoot more. However it adds weight and size. I whll just carry lots of batteries in my pocket. Keeping it light and small is the essence why i buy mft and fuji as my travel camera but it just me...to each his own.
Offline retret66
  • Extreme Hobbyist
  • Liked: 11
  • Mabuhay!
  • Camera: Sony
  • Model: A7s, A7II, A7RMK2
  • Nickname: retret
« Reply #6 on: July 02, 2016, 10:29:53 PM »
same here, adding grip to a mirrorless defeats the purpose and you might as well buy DSLR. The main reason I sold mine when I had it on sony is that when you have a zoom attached, the strap no longer hugs your body because the lens mount will be about 2" from each side, it is really not practical to hike and camera is swinging all over the place. Without the grip, the lens mount is very close to the edge and this side will be hanging against your body...
https://www.flickr.com/photos/129168751@N04/  Sony A7R2, Canon 200mm F2/L USM IS, Zeiss Batis 85mm F1.8, Canon MP-E 65mm Macro
Offline pitbull
  • Impeous Man
  • Trade Count: (42)
  • Liked: 1124
  • Patron ng mga Kolehiyala
    • Ang blog ng mga pogi
  • Camera: X20
  • Nickname: Ninong
« Reply #7 on: July 02, 2016, 10:49:13 PM »
ano nanaman kayang worlds fastest feature ngayon? mura na XT-1 dito :o :o :o
  • Liked: 12
  • Nickname: vt
« Reply #8 on: July 05, 2016, 12:41:02 PM »
more leaked photos, just 2 more days until official announcement. ;)
http://www.fujirumors.com/leaked-fujifilm-x-t2-ef-x500-vertical-grip-mhg-xt2-images/
« Last Edit: July 05, 2016, 12:44:34 PM by gravija_flare »
Offline AJ72
  • Mabuhay!
  • Camera: Canon, Sony
  • Model: A7Rii, 80D, NEX5R
  • Nickname: AJ
« Reply #9 on: July 05, 2016, 07:28:33 PM »
For me, size wasn't the primary reason for getting mirrorless, it was the EVF.  Second was weight, although you can argue that a smaller size leads to lighter weight.  Actually, I prefer having the grip on since I find it easier to hold on to the camera because I have big hands.  If not for the weight, I prefer the feel of a DSLR in my hands.  That EVF tho...
Anyway, looks like a good successor to the X-T1 - except for the lack of touch screen
  • Liked: 12
  • Nickname: vt
« Reply #10 on: July 07, 2016, 08:38:35 AM »
the x-t2's official page in cameraworld uk already up! other sites soon to follow..
http://www.fujirumors.com/online-now-full-fujifilm-x-t2-presentation-specsimagesproduct-description/
  • Liked: 12
  • Nickname: vt
« Reply #11 on: July 07, 2016, 01:11:56 PM »
the updated x-mount lens roadmap. a trio of weather resistant prime lenses: 23mm f2, 50mm f2 and 80mm f2.8 macro. ;)
http://www.fujifilm.com/products/digital_cameras/xf_lens/roadmap/
  • Liked: 12
  • Nickname: vt
« Reply #12 on: July 07, 2016, 01:49:01 PM »
x-t2 official price is 1599 usd for the body only, while the x-pro2 is at 1699 usd. so for 100 usd less, you get more autofocus points, 4k video, 3-way tilting lcd, bigger evf, dual uhs-II card slots and more grip options. ;)
Offline retina
  • Global Moderator
  • Liked: 1046
  • Camera: Fujifilm
  • Model: Nikon D750
  • Nickname: Doc A
« Reply #13 on: July 07, 2016, 07:38:34 PM »
x-t2 official price is 1599 usd for the b3ody only, while the x-pro2 is at 1699 usd. so for 100 usd less, you get more autofocus points, 4k video, 3-way tilting lcd, bigger evf, dual uhs-II card slots and more grip options. ;)
Whether it is worth it at that price depends on who is talking and on someones need. Each one have a different point of view. I will be happy for the early adopters and BI us along the way....
Offline pogzz505
  • "God is good all the time"
  • Trade Count: (3)
  • Liked: 195
  • Camera: Fujifilm
  • Model: X-T10
  • Nickname: Romel
« Reply #14 on: July 08, 2016, 02:14:19 AM »
puro x-t2 na video sa you tube.
Offline Fox_Two
  • Liked: 32
  • Gotcha!
  • Camera: Canon
  • Field: Still Life
  • Model: Canon 7DM2 | Sigma 35mm f/1.4
  • Nickname: Rich
« Reply #15 on: July 10, 2016, 06:28:09 PM »
I've seen the recent marketing materials and I noticed nobody is bragging about having the world's fasted AF anymore. At least the expectations are realistic this time. With that being said, I still don't think it will beat the Canon 7D Mark II or Nikon D500 in the AF speed and accuracy arena.  Of course, there are improvements and they're headed in the right direction.  But at this point in time, you're buying it primarily for its image quality output, specifically the color rendering, the way I see it for myself as a portrait photographer.  Slap a 35mm f/1.4, 56mm f/1.2 or the forthcoming 80mm f/2.8 macro up front and I'd be a happy camper.
« Last Edit: July 10, 2016, 06:31:01 PM by Fox_Two »
”Your eye must see a composition or an expression that life itself offers you, and you must know with intuition when to click the camera...."  - Henri Cartier-Bresson
Offline retina
  • Global Moderator
  • Liked: 1046
  • Camera: Fujifilm
  • Model: Nikon D750
  • Nickname: Doc A
« Reply #16 on: July 10, 2016, 08:04:22 PM »
I am curious about the new 23mm F2( reminiscence of the x100s that i used to have.). but since it will be quite sometime before the prices will stabilized, plenty of time to wait for the users review....not the paid ones but the would be gassers. This is a nice camera for sure but this is not a revolutionary one. I can still skip this one and wait for the X-T3. One thing I like about the Fuji are the lenses and they are getting many around. I will opt for the primes like the ones you've mentioned.
  • Liked: 12
  • Nickname: vt
« Reply #17 on: July 11, 2016, 12:48:15 PM »
i'm interested in these smaller and weather-resistant lenses as well, particularly the 23mm and 50mm.. but i do wish that they'll have smaller and weather-resistant bodies too. perhaps an x-e3 wr or x-t20 wr?  ;D
Offline retina
  • Global Moderator
  • Liked: 1046
  • Camera: Fujifilm
  • Model: Nikon D750
  • Nickname: Doc A
« Reply #18 on: July 11, 2016, 01:50:59 PM »
That would be irresistible...
  • Liked: 12
  • Nickname: vt
tentative release dates of the upcoming wr prime lenses
« Reply #19 on: July 26, 2016, 08:07:51 AM »
from fujifilmxmagazine.eu's lastest issue, they cover the x-t2 and reveal the planned release dates (though probably still tentative) of the upcoming wr prime lenses:
23mm f2 - oct 2016
50mm f2 - spring 2017
80mm f2.8 - end of 2017
hopefully, the ph release will not be far behind. ;)
http://en.fujifilmxmagazine.eu/15/#page3
« Last Edit: July 26, 2016, 08:10:09 AM by gravija_flare »
Last post March 27, 2007, 10:00:42 PM
by HartSord
Last post August 20, 2007, 04:26:37 PM
by jasondeg
Last post October 15, 2009, 02:07:55 PM
by indieridley
Last post September 10, 2009, 03:44:23 PM
by rtsy
Last post November 18, 2011, 02:28:20 PM
by fcabuslay
