Author Topic: [FLASH] Yong Nuo YN-560 Flash for Strobist (Free Diffuser/3Mos Warranty)  (Read 3936 times)
*Includes 3 Month Full Replacement Warranty and One Free Hard Case / Stofen Omnibounce Diffuser
YN560 is a brand-new flash specially designed for professional creative photography. Compared with YN460-II and YN460, it has the following brand new features
Features
A brand new appearance
The brand new appearance looks more beautiful, creditable, comfortable and professional.
New power zoom function
By pushing the button on the flash, it can make the flash covered focal length range from 24 to 105mm.
GN58 @ ISO100, 105mm
YONGNUO gives YN560 a higher guide number which reaches the level of the mainstream hot shoe flashes.
The improved wireless triggering sensor
YONGNUO improves the wireless triggering sensor for YN560, which makes the S1 and S2 mode can be used in outdoor environment and the wireless triggering distance is as long as 15m..
Sound indicator
When the charging process is finished, the flash will give a tick sound, so you may concentrate on the creation process. (Note: the sound can be closed).
New charging socket for external power pack
YN560 adds a charging socket for external power pack, to meet your higher demand for charging recycle.
New PC synchronous port
YN560 adds a standard PC synchronous port, which makes it simpler for you to use the PC synchronous line.
Super speed of charging recycle
It only takes 3 seconds in charging after full power output. Even without new batteries, you can get the super charging speed that it only needs 4~5 seconds; so you can completely get rid of the nightmare of anxious waiting for charging. In addition, you can use the external power pack to accelerate the charging speed once more.
Supporting high-speed continuous shooting
Under the output level of 1/8 or below, YN560 can support the 8FPS high-speed continuous shooting.
The improved power saving mode
YONGNUO designs the power saving mode for YN560. In the power saving mode, the flash will get automatic shutdown sooner; in the non-saving mode, it will take a longer time before automatic shutdown.
The more fine output control
The output control of YN560 is more fine, which ranges from 1/128 to 1/1 and each class of flash output has 8 small fine tuning stalls; With its zooming flash head, YN560 makes you nearly achieve your anticipant lighting effect.
The automatic setting saving
YN560 can automatically save your current setting.
Technical Specifications
Model information
• Brand    Yongnuo
• Model    YN560
• First introduction    2010
• Successor    none yet
Output specs
• Guide Number (m)    39 / ~34 (ISO 100, 35mm)
• Manual Power Settings    1/1 – 1/2 – 1/4 – 1/8 – 1/16 – 1/32 – 1/64 – 1/128
• Flash duration (full power)    1/200
• Recycle time specified (full power)    3 sec alkaline
• Recycle time measured  (full power)    3.4 sec alkaline, 1.6 sec NiMH
Flash head features
• Swivel    -180 to +90 degrees
• Tilt    -7 to +90 degrees
• Manual zoom head    (18) 24-105
• Auto zoom    no
• 2nd reflector    no
• LCD display    no
Triggering
• Flash foot type    standard
• PC Synch Port    yes
• Optical slave    2 modes (1 w/ pre-flash suppresion)
• Other trigger    none
• Trigger voltage    3.25 V (measured)
• Standby mode    can be adjusted (30 mins max)
Power supply
• Batteries used    4 x AA
• External power source    Yongnuo SF-18C or SF-17C
External Reviews
Speedlights.net  - http://speedlights.net/2010/07/14/yongnuo-yn-560-speedlite-review/
The YN-560 is a speedlite that offers everything you need for strobist work at a very reasonable price: and for the price premium over the YN-460 mk2 you get a much better build quality and a very usable optical slave – plus even a sync terminal now. If you’re after sheer power though and don’t care about the rest then you can keep your YN-460-II. But the new YN-560 definitely does deserve the “AAA” strobist score.
YN-560 Positives
• excellent build quality
• powerful (though not a strong as specs suggest)
• extremely fast recycle times (plus power pack socket)
• 3 ways to trigger: flash foot, 2 optical slave modes, PC sync socket
• optical slave mode now even working in bright sunlight (EV 14 tested)
• dedicated “+” and “-” buttons for zoom & power level setting
• very easy to use and quick to change settings
• standard size (same as Canon 580EX) flash head
• optional recycle beep signal
YN-560 Negatives
• output not on specified level – does not reach GN 39
• blocks power switch on RF-602 radio receiver when mounted
• current zoom setting only visible when pressing a button
• partial output setting in odd steps (not 1/2 or 1/3)
• simple pouch rather than padded soft case
Strobist.com / David Hobby - http://strobist.blogspot.com/2010/08/test-drive-yongnuo-yn-560.html
The new, $85(!) flash has two important features which potentially potentially make it an good addition to a lighting photographer's bag: A built-in slave and an external sync jack.
Any shoe-mount flash with that kind of bling deserves a look.
It feels like a much more expensive flash, aping the lines of the similarly named Canon EX-580 II. The battery door is captive and hinged (a plus over the LP160) and very well-designed. The battery polarity sticker is a nice touch for guys like me who are putting off getting bifocals. (That bell tolls for me in three weeks -- I am officially old.)
What can I say. I found the 560's controls to be both fantastic and maddening.
On the plus side, you get a 1/1 - 1/128 power range. This is unheard of in the sub-$100 price range, but they go and include eight steps of variability between each stop. Amazing in theory, but in practice the flash's consistency tops out in the ~1/3-stop range. In other words, it ain't a Profoto D1, but I really like where they are aiming. You have to give them major props for that little trick. Advantage: YN-560.
That was the spoonful of sugar. Now here's the medicine.
The flash uses a row of 8 LEDs across the back display to give the following info:
1. Zoom head angle: This is the only function that is actually labelled, and a tad ironically so for me given that my zoom motor did not work.
2. Power range, from 1/1 to 1/128: When adjusting the power with the left/right buttons, the dot scale represents overall flash power -- but is not labelled as such. You have to count the dots. That's a dumb miss -- what were they thinking?
3. Intra-stop power range: When using the up/down buttons, this adjusts the power between stops. Again, no labels, and going for the third indicator from the same set of LEDs gets problematic when it comes to labeling.
Price - P3500
« Last Edit: July 06, 2012, 01:36:47 PM by lehboy »
Re: [FLASH] Yong Nuo YN-560 Flash for Strobist
« Reply #1 on: December 09, 2010, 07:18:07 PM »
This item currently on sale from the regular price. Now at P3500
« Reply #2 on: December 10, 2010, 10:42:09 AM »
up up
Offline rljavierto
  • Liked: 49
  • Model: Fuji film X10, Nikon D7000
  • Nickname: Ryan
« Reply #3 on: December 10, 2010, 01:33:49 PM »
Sir pwede ba to sa Nikon D90? Thanks
Cheers!
« Reply #4 on: December 10, 2010, 01:35:55 PM »
yes it can work with the D90
Offline rljavierto
  • Liked: 49
  • Nickname: Ryan
« Reply #5 on: December 10, 2010, 01:50:28 PM »
Sir, which one would you best recommend YN-560 or the NISSIN Di622 for D90?  I bought from you Nissin for my 1st DSLR Canon 1000D and I like it, now I upgraded to Nikon D90 and wanted to buy from you a good alternative for sb600 I cannot afford.  Thanks in advance for your advise.
Cheers!
« Reply #6 on: December 10, 2010, 02:29:28 PM »
Ah, the nissin di622 has TTL functions while this one is a fully manual flash.
This is actually a good secondary flash for strobist purposes but if you want another one that has TTL functions definitely get the nissin.
Offline rljavierto
  • Liked: 49
  • Nickname: Ryan
« Reply #7 on: December 11, 2010, 03:58:32 PM »
A ok sir, how much is the Nissin Di622 mark2? Kindly pm the price, I am interested.  Thanks for the advise.
Cheers!
Offline S13
  • Kamera Kolektor
  • Trade Count: (6)
  • Rangefinder Junkie
« Reply #8 on: December 13, 2010, 07:40:06 PM »
Will this work on a Canon 1D mkI?
« Reply #9 on: December 21, 2010, 01:33:27 PM »
very limited stocks remaining...
Offline shuttershotmigo
  • Trade Count: (21)
    • shuttershotmigo.multiply.com
« Reply #10 on: December 21, 2010, 01:48:06 PM »
yes! i've been using this with my 1D since august! so far so good! =D
Who loves photography?
Offline t_s_o_n_g
  • Nido Kid
« Reply #11 on: December 22, 2010, 11:00:03 AM »
Can this be triggered by Phottix PT-04II? If yes, do you have Phottix PT-04II receiver only?
« Reply #12 on: December 22, 2010, 11:38:02 AM »
Yes it can, and yes we have the receiver only
Offline Alizarine
« Reply #13 on: December 30, 2010, 02:02:36 AM »
Hi! Will this flash work with a Pentax K-x? Interested in buying within the next 2 weeks~
if not... oh well :(
Offline glenstr
  • Nido Kid
« Reply #14 on: January 06, 2011, 06:59:12 PM »
Hi sir may warranty po ba kayo na offer?
« Reply #15 on: January 11, 2011, 04:32:34 PM »
this will be hopefully be back in stock late this week or early next week
Offline carl.casequin
  • Trade Count: (4)
  • Liked: 51
« Reply #16 on: April 28, 2011, 12:23:35 PM »
Price update and availability please :)
Is there a newer version of this flash?
« Reply #17 on: April 28, 2011, 12:34:07 PM »
still same price. stocks will arrive end of this week.
Offline dhyazzperr
« Reply #18 on: June 25, 2011, 01:26:52 AM »
how about warranty?
« Reply #19 on: July 25, 2011, 12:19:55 PM »
still available!
Last post January 11, 2010, 12:22:27 AM
Last post January 26, 2011, 10:39:20 PM
by kionne
Last post January 18, 2011, 10:14:58 AM
Last post April 26, 2012, 02:44:53 PM
Last post June 15, 2012, 12:42:13 PM
