literal na street photography.. hehehe..
Nikon D90+Kitlens
SOOC
Exif data
Camera Nikon D90
Exposure 2
Aperture f/11.0
Focal Length 38 mm
Focal Length 37.8 mm
ISO Speed 800
Exposure Bias 0 EV
Flash No Flash
Orientation Horizontal (normal)
X-Resolution 300 dpi
Y-Resolution 300 dpi
Software Ver.1.00
Date and Time (Modified) 2011:02:18 05:53:59
White Point 0.313 0.329
Primary Chromaticities 0.64 0.33 0.21 0.71 0.15 0.06
YCb Cr Coefficients 0.299 0.587 0.114
YCbCr Positioning Co-sited
Exposure Program Manual
Date and Time (Original) 2011:02:18 05:53:59
Date and Time (Digitized) 2011:02:18 05:53:59
Compressed Bits Per Pixel 4
Max Aperture Value 4.4
Metering Mode Multi-segment
Light Source Unknown
Sub Sec Time 00
Sub Sec Time Original 00
Sub Sec Time Digitized 00
Color Space Uncalibrated
Sensing Method One-chip color area
CFAPattern [Green,Blue][Red,Green]
Custom Rendered Normal
Exposure Mode Manual
White Balance Auto
Digital Zoom Ratio 1
Focal Length In35mm Format 57 mm
Scene Capture Type Standard
Gain Control Low gain up
Contrast Normal
Saturation Normal
Sharpness Normal
Subject Distance Range Unknown
Gamma 2.2
Maker Note Version 2.10
ISO 800
Quality Fine
White Balance Auto
Focus Mode AF-C
Flash Setting Normal
White Balance Fine Tune 0 0
WB_ RBLevels 1.49609375 1.51953125 1 1
Program Shift 0
Exposure Difference -1.0
Flash Exposure Comp -1
ISOSetting 800
Image Boundary 0 0 4288 2848
Flash Exposure Bracket Value 0.0
Crop Hi Speed Off (4352x2868 cropped to 4352x2868 at pixel 0,0)
Exposure Tuning 0
Serial Number 2211024
Color Space Adobe RGB
VRInfo Version 0100
Vibration Reduction On
Active D- Lighting Auto
Picture Control Version 0100
Picture Control Name Vivid
Picture Control Base Vivid
Picture Control Adjust Default Settings
Picture Control Quick Adjust Normal
Sharpness 4
Contrast Normal
Brightness Normal
Saturation Normal
Hue Adjustment None
Filter Effect n/a
Toning Effect n/a
Toning Saturation n/a
Timezone +09:00
Daylight Savings No
Date Display Format M/D/Y
ISOExpansion Off
ISO2 800
ISOExpansion2 Off
Lens Type G VR
Lens 18-105mm f/3.5-5.6
Flash Mode Did Not Fire
Shooting Mode Single-Frame
Lens FStops 5.33
Shot Info Version 0213
Firmware Version 1.00
Shutter Count 15125
Noise Reduction Off
WB_ RGGBLevels 2848 0 0 0
Lens Data Version 0204
Exit Pupil Position 102.4 mm
AFAperture 4.5
Focus Position 0x04
Focus Distance 5.62 m
Lens IDNumber 158
Min Focal Length 18.3 mm
Max Focal Length 106.8 mm
Max Aperture At Min Focal 3.6
Max Aperture At Max Focal 5.7
MCUVersion 160
Effective Max Aperture 4.5
Retouch History None
Image Data Size 4081196
Flash Info Version 0103
Flash Source None
External Flash Firmware n/a
External Flash Flags (none)
Flash Commander Mode Off
Flash Control Mode Off
Flash GNDistance 0
Flash Color Filter None
Flash Group AControl Mode Off
Flash Group BControl Mode Off
Flash Group CControl Mode Off
Flash Group AExposure Comp 0
Flash Group BExposure Comp 0
Flash Group CExposure Comp 0
Multi Exposure Version 0100
Multi Exposure Mode Off
Multi Exposure Shots 0
Multi Exposure Auto Gain Off
High ISONoise Reduction High
Power Up Time 2011:02:18 05:50:53
AFInfo2 Version 0100
Contrast Detect AF Off
AFArea Mode Dynamic Area
Phase Detect AF On (11-point)
Primary AFPoint Center
AFPoints Used Center
Contrast Detect AFIn Focus No
File Info Version 0100
Directory Number 100
File Number 4839
Compression JPEG (old-style)
XResolution 300
YResolution 300
Resolution Unit inches
Preview Image Start 10348
Preview Image Length 25689
YCb Cr Positioning Co-sited
Light Switch LCD Backlight
AFArea Mode Setting Dynamic Area
Center Focus Point Normal Zone
AFAssist On
AFPoint Illumination On
Focus Point Wrap No Wrap
AELock For MB- D80 AE/AF Lock
MB- D80 Battery Type LR6 (AA alkaline)
Beep On
Grid Display On
ISODisplay Show ISO Sensitivity
Viewfinder Warning On
No Memory Card Release Locked
Screen Tips On
File Number Sequence On
Shooting Info Display Auto
LCDIllumination Off
Easy Exposure Comp Off
Reverse Indicators + 0 -
Exposure Control Step Size 1/3 EV
Center Weighted Area Size 8 mm
Fine Tune Opt Matrix Metering 0
Fine Tune Opt Center Weighted 0
Fine Tune Opt Spot Metering 0
CLMode Shooting Speed 4 fps
Exposure Delay Mode Off
Auto Bracket Set AE & Flash
Auto Bracket Order 0,-,+
Func Button FV Lock
OKButton Select Center Focus Point
AELock Button AE/AF Lock
Command Dials Reverse Rotation No
Shutter Release Button AE- L Off
Metering Time 16 s
Remote On Duration 1 min
Self Timer Time 5 s
Self Timer Shot Count 1
Playback Monitor Off Time 10 s
Image Review Time 20 s
Menu Monitor Off Time 20 s
Shooting Info Monitor Off Time 10 s
Flash Shutter Speed 1/60 s
Internal Flash TTL
Manual Flash Output Full
Repeating Flash Output 1/32
Repeating Flash Count 10
Repeating Flash Rate 10 Hz
Flash Warning On
Commander Internal TTLComp 0
Modeling Flash Off
Auto FP On
Commander Group A_ TTLComp 0
Commander Group B_ TTLComp 0
Live View AF Normal Area
