Author Topic: Photobooth Templates  (Read 52753 times)
0 Members and 2 Guests are viewing this topic.
Offline miz3girl
Re: Photobooth Templates
« Reply #140 on: May 12, 2011, 11:38:24 AM »
send mo agad ang pics and design instructions...
Thank you sa mga nag comment and nagbigay ng advice.  Finally nagwork na rin using my own template after ko in-install yung new printer.  i used a canon selphy cp800 and everything works great.
ask ko lang po...saan ba ako makakabili or kuha ng ibat ibang brushes for photoshop?
Offline strider19
« Reply #141 on: May 12, 2011, 01:04:58 PM »
sabi ko na kelangan mo lang install yung printer..regarding photoshop brushes..ang daming free..contact google  ;D
« Last Edit: May 12, 2011, 01:06:39 PM by strider19 »
Offline miz3girl
« Reply #142 on: May 27, 2011, 11:27:03 PM »
gusto ko lang pong magpasalamat sa inyo at naging successful yung photobooth event ng baby ko.  dahil sa tulong at advice nyo, nag enjoy ang mga bisita namin.
meron po ba dyan makakapagbigay ng info kung paano ko magagawa na angle ang position ng picture?
TIA!
Offline strider19
« Reply #143 on: May 28, 2011, 06:21:19 AM »
TIA!
File > Photobooth Settings>Custom Layout Settings
then maglagay ka ng values sa rotation across image number para mag tilt ang image.
Offline rak1sta
  • Trade Count: (10)
  • Liked: 3
    • Pinoy Transcriptions, atbp.
« Reply #144 on: May 28, 2011, 04:56:23 PM »
yes, experiment ka lang po sa angle ng rotation.
madalas ko yun gamitin para maiba ng kaunti..
pero ok rin naman kahit wala rotation... depende rin po syempre sa preference ng customer.
« Last Edit: May 28, 2011, 05:01:35 PM by rak1sta »
rock and roll
Offline skylynx888
  • Trade Count: (3)
  • Liked: 14
  • Breastmilk is still best for babies
« Reply #145 on: May 28, 2011, 05:09:05 PM »
i like the idea regarding the rotation.. question lang po:
- d ba we get the values sa photoshop, panu na pag may rotation? how will the pictures fit po?
thanks
Offline strider19
« Reply #146 on: May 28, 2011, 05:15:58 PM »
thanks
ang ginagawa ko get the values from photoshop.. then plot in settings with rotation...then take sample printout (saved copy only). then adjust mo na lang layout mo sa photoshop from the sample.
Offline skylynx888
  • Trade Count: (3)
  • Liked: 14
« Reply #147 on: May 28, 2011, 05:22:38 PM »
thanks for input sir, will try this out, may time pa naman ako mag layout for the next event....  ;) ;)
regarding din pala sa overlay.png, bakit kaya wala pictures lumalabas dun sa final output, pero pag background.jpg eh okay naman?  is there a difference po ba sa pag layout?
Offline miz3girl
« Reply #148 on: May 28, 2011, 10:11:28 PM »
thank you sa reply!  experiment ko mamya yung rotation.
sa mga nag ooperate na ng photobooth, ask ko lang kung how much ang bayad nyo pagnagpapagwa kayo ng personalized backdrop?  yun po kasing pinag orderan ko, charge nila 1350 PHP for 5x6 na width and ang material na ginamit ay lona/tarpauiln material.  meron po bang alternative na puedeng gamitin na medyo mura?  kasi yung KP108 ink dito ay super mahal compare dyan sa pinas and to add ang cost ng tarp lalong tumataas ang cost.  share naman po ninyo experience nyo.  more power to all!
Offline jubeken
  • Nido Kid
« Reply #149 on: May 28, 2011, 11:17:24 PM »
Sir pano nyo po nagagawa na nakarotate then nagooverlap po yung mga pictures? pano po nyo po nakukuha yung sukat nila sa photoshop? tnx
Offline rak1sta
  • Trade Count: (10)
  • Liked: 3
« Reply #150 on: May 29, 2011, 11:19:37 PM »
Kukunin ko po muna sukat sa Photoshop ng hindi nakarotate, then adjust ko na lang sa NK ang rotations.  makikita mo namana sa preview yun.  Magooverlap yung pictures talaga kung magpapatong ang coordinates nila.  yung huli lagi ang nasa ibabaw so dun mo na didiskartehan kung anong pic ang gusto mo nasa ibabaw.  :)
rock and roll
Offline bynxty
  • Liked: 2
  • Gender: Female
« Reply #151 on: May 30, 2011, 12:11:19 AM »
TIA!
glad to know it went well!
Offline neesnu
« Reply #152 on: May 30, 2011, 12:33:23 AM »
@all
Guys, ano usually size ng tarpaulin backdrop na pinapagawa nyo? yung common.. thanks!
Offline strider19
« Reply #153 on: May 30, 2011, 05:42:10 AM »
@all
5'X6'
Offline yven4
« Reply #154 on: June 13, 2011, 03:24:52 PM »
HI sir...
Pa check po ng printer set up... paper size should be set to 4x6. Printer properties is set to 4x6 din so bale sa dalawang lugar kau dapat mag set ng size ng paper... also ang default kase is 8.5x11. Evrytime na iclose nyo ung program nag rereset sya.
If naka 4x6 na.. tapos ganun pa din.. you may check your background.jpeg and make sure that the size is 4x6 din...
Ganito rin problem ko, before ko ginawa background na set ko na into 4x6 ung background then pag nag piprint ako ganito lumalabas :( same narin printer set up ng nkremote at printer ko.... Need help ASAP 1st event ko kasi this coming wednesday evrything is ok na except for the lay out. Help mga master.
Thank in advance
Offline mivec
    • Jake's Portfolio
« Reply #155 on: June 21, 2011, 07:07:16 PM »
Try to use photoshop...
then create a 4x6 document... then use slice tool
 try mo mag slice then right click may makikita kang edit slice, click mo un then it will give you the coordinate and size ng slice mo...
then the design is up to your imagination.. you would hve to do it from a blank page. You would have to create your own customized template. The concept of using slice tool can help you to load your design sa NKremote or DSLR remote..
you can call me at 09228843978 para ma explain ko ng mabuti
hmm was just backreading and eto yung nadalian ako, so lets say 5x7 yung print ko, gagawa ako blank na template sa photoshop, dun ko ilalagay yung frame then lagay ng pic afterwards? tama ba  :o gagawa kasi ako sa jul 4 ng mga portraits para sa isang corporate event na ala photobooth ang dating...
addicted to shooting stills...
Offline mivec
    • Jake's Portfolio
« Reply #156 on: June 21, 2011, 07:10:12 PM »
master panu mo nagawa yung iba dito? :) kahit yung sa pag gawa ng frame gaya ng 3rd pic? thanks
Offline markraymond
« Reply #157 on: June 21, 2011, 10:40:28 PM »
sa pho fussion mo gawin yung overlay mo makikita mo rin dun yung x & y axis + yung agle ng rotation.
Offline rak1sta
  • Trade Count: (10)
  • Liked: 3
« Reply #158 on: June 24, 2011, 08:58:55 PM »
So Photoshop lang po, sir :)
Wag na po master dahil pag may master, may slave hehe.  ^_^
rock and roll
Offline rak1sta
  • Trade Count: (10)
  • Liked: 3
« Reply #159 on: June 24, 2011, 09:06:00 PM »
share ko lang po test shots hehe
rock and roll
Tags: Rotation
Last post May 30, 2006, 12:10:10 AM
by dni
Last post December 23, 2008, 10:22:47 PM
by barbz09
Last post September 14, 2010, 11:10:00 AM
by whitecato0619
Last post January 07, 2013, 12:58:24 PM
by thekneelaw
Last post October 12, 2010, 01:31:31 AM
by skielan
