Author Topic: Batteries for Flash  (Read 1297 times)
Offline mervic
Batteries for Flash
« on: April 04, 2010, 04:05:01 PM »
mga sirs inquiry lang, im planning to buy a 580exII and i don't know w/c battery to buy. please advice naman po kung anu mganda batteries na bilhin. Thanks
Offline jet
  • nooobbb..
  • Trade Count: (27)
  • Liked: 1
Re: Batteries for Flash
« Reply #1 on: April 04, 2010, 04:06:00 PM »
Try eneloop batteries..  ;)
Offline kapitanmike
  • A brother from Pilar lodge No. 15 GLP
  • me u cnnt ps.
« Reply #2 on: April 04, 2010, 04:30:58 PM »
look for low self discharge batts
eneloops are popular and more common nowadays... 2000mah
if you can still find hybrios i find that these last longer ( just a little lang naman ) 2100mah kasi ( i use these )
medions are ok din daw tho i havent used these personally
Res Ipsa Loquitor
Keep Shooting!!!
Offline squidballz
« Reply #3 on: April 04, 2010, 09:17:00 PM »
i have the same flash and i use eneloops. I think meron sa cdr-king. Not sure kung meron sila nung me ksamang charger.
Offline mervic
« Reply #4 on: April 04, 2010, 10:21:53 PM »
salamat po mga sirs. ;D
Offline pjflordeliz
  • Liked: 3
« Reply #5 on: April 04, 2010, 10:50:22 PM »
when i bought my 430 EX II last dec, i paired it up with Ansmann 2500mAh batteries and included charger..so far so good..it never got fully discharged when im using it in events..i think 400++ ETTL flashes and its up and running pa rin :D
-= United Canon Rebels =-
Offline cianzepol
« Reply #6 on: April 05, 2010, 01:03:11 PM »
use sanyo eneloops sir.
ok na ok yun.
Offline bluegene
« Reply #7 on: April 05, 2010, 05:41:31 PM »
Eneloop the best talaga yan.
Offline jangg
« Reply #8 on: April 05, 2010, 07:20:24 PM »
Eneloops. Hands down. There simply is no other option. :)
Offline bluegene
« Reply #9 on: April 06, 2010, 12:50:49 AM »
puwede na rin yung Energizer na alkaline as back-up for emergencies.
Offline jangg
« Reply #10 on: April 06, 2010, 01:00:45 AM »
Mahal kasi ang energizer. Whereas you can buy a pack of 4 eneloops for just 500, multiple uses pa because it's rechargeable.
Offline makumak2009
« Reply #11 on: April 06, 2010, 02:06:58 AM »
Eneloops are pretty much popular these days so you give that a shot. Plus it's not that expensive compared to buying energizer batteries.
Offline comecum
« Reply #12 on: April 13, 2010, 10:01:25 PM »
Eneloops here, kaso hirap maghanap, most cdrking branches wala silang stocks lalo na dito sa Cavite.
Canon 550D, kit lens, Canon 50mm 1.8, Tamron 17-50m VC, Yongnuo YN565, Eureka 48L dry box.
Offline ubermensch
  • Trade Count: (31)
  • Liked: 3
« Reply #13 on: April 13, 2010, 10:19:22 PM »
used to have eveready (2000mAh, color green) and sanyo (2100mAh, color white and orange). yung eveready may kasamang slow charger. 3 years old na sila pareho.
used them sa sb600 ko alternately ngayon ginamit ko na rin sa yungnuo slave flash. napansin ko bilis na nila maubusan. baka kasi old na rin sila. so when i got an sb900, bought eneloops na rin with fast charger. ayus! hindi pumapalya kahit burst. pero siyempre maingat ako sa overheat..
Offline Adrian Jose
  • Liked: 2
    • Adrian Checa Photography
« Reply #14 on: April 13, 2010, 10:24:37 PM »
Sanyo Eneloops. Tried and tested...
Offline cheefer
  • Trade Count: (4)
« Reply #15 on: April 13, 2010, 11:53:04 PM »
Eneloops are a good choice as they can hold their charge for long periods of time
Offline creationz
  • Trade Count: (4)
  • Liked: 2
    • few pix in my multiply
« Reply #16 on: April 14, 2010, 07:41:38 AM »
i guess hands down to eneloop.  ;)
Think out of the box.
Offline nielladia
  • Camera: Sony
  • Model: Nex 3N
« Reply #17 on: April 14, 2010, 07:52:46 AM »
On another side, Powerex Imedion 2100 mAh also hold their charge for a long time. You can pair it up with Maha C204w (ata) with a refresh function help those batteries perform better after years of using it. Just my 2cents.  ;D
Offline bl@ze_01
« Reply #18 on: April 14, 2010, 08:11:42 AM »
I also have the Powerex Imedion (included with the Powerex charger).. had a chance to compare it with the eneloop batts in a shoot using 2 flashes and it ended up beating the eneloops with regards to recycling time.. settled for this because it also has the eneloop's ability to retain at least 80% of its charge (as advertised) after long periods of non-usage.  ;D
Canon 50D │ Canon 10-22 │ Sigma 70-200 f2.8 II │ 50mm f1.8 │ 430EX II │ FotoPro X-4i │ Crumpler 7MDH │ Kata DR-466i
Offline jangg
« Reply #19 on: April 16, 2010, 02:00:39 AM »
Ah yeah. I noticed that with Eneloops. Pag medyo low na ang charge, mabagal na ang recycling time.
Last post January 29, 2007, 03:57:19 PM
by joya
Last post January 30, 2007, 05:43:53 PM
by bitoy
Last post February 05, 2008, 11:57:41 PM
by nap
Last post October 22, 2009, 02:27:00 PM
by quixilver
Last post December 11, 2011, 03:59:34 PM
by xiandgreat
